Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De vernieuwde 2001 Dodge Caravan en 2001 Chrysler Town & Country werden onthuld op de North American International Auto Show op 10 januari 2000 en kwamen in augustus 2000 op de markt.
How to replace Front Heater Core?
Can someone post graphical pictures and Step by Step guide for removing Dash and replacing the Front Heater Core in a 2006 Dodge Caravan.
Is dit een goede vraag?
Score 2
2 opmerkingen
I can't get the clip off the side of the brake to be able to lower the brake pedal. Any ideas?
door Deel
I have a 2005 Dodge Grand Caravan. does anyone have any 4-1-1 on how to get heater core around the motor for the gas/break pedal height adjustment? It's a real challenge for me. Please help!!!!
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Sorry no pictures :)instructions at http://www.ehow.com/how_4520846_replace-...
Replacing the Front Heater Core
1 Turn the steering wheel so that the wheels point straight forward.
2 Disconnect the negative (black) battery cable.
3 Drain the coolant by twisting open the valve at the bottom of the radiator. Use a clean container that holds at least 10.5 quarts. You will reuse the coolant later.
4 Remove the panel on the lower left side of the steering column and disconnect the parking brake cable with a pair of pliers.
5 Unscrew the 10 bolts that connect the steering column cover liner to the instrument panel and remove the cover.
6 Turn the key to the LOCK position and turn the steering wheel to the LOCKED position.
7 Unhook the gear shift cable and remove its mounting bracket.
8 Unscrew the two screws that connect the bezel to the instrument panel and remove the retaining clips. Remove the bezel.
9 Remove the two screws that connect the steering column shroud to the column and remove the shroud.
10 Remove the coupler from the steering column and intermediate steering shaft.
11 Loosen the nuts that connect the lower steering column mounting bracket, but do not remove them. Completely remove the two nuts and washers from the upper bracket.
12 Pull out the steering column.
13 Remove the interconnect and bracket that connects the instrument panel to the chassis wiring.
14 Remove the boot from the bottom of the steering shaft.
15 Use locking pliers to pinch off the heater hoses in the engine compartment. Remove the plate covering the heater core (the hoses run through it) and disconnect the hoses.
16 Unclip the connectors that hold in the heater core. Lift the accelerator pedal to enable you to slide the heater core out part way. Press the brake pedal to make room to completely remove the heater core.
17 Replace the heater core. Installation is the reverse of removal. The nuts on the steering column mounting bracket should be torqued to 105 ft. lbs. Torque the pinch bolt on the coupler to 21 ft. lbs.
It is available at http://www.redlinemotive.com/replacement... and of course here http://www.car-stuff.com/dodgeheatercore... not cheap :)
Good luck.
Was dit antwoord nuttig?
Score 7
7 opmerkingen:
+ getting good at research ;-)
door Deel
+ This is a job I think I'd pass on doing--wow.
door Deel
impressive! +
door Deel
can I get a video or more about how to replace the heater core ???? please its a pain in the but the steps I have got told are not getting me very far, thanks
door Deel
@ sarah, did you follow the steps listed in the original answer? Those are from the repair manual
door Deel
2 commentaren meer tonen
i did most of what the response said however i didnt completely remove the steering shaft simply remove the one bolt and took off the plastic cover at the base and lifted the shaft up and slid out the core whole job took me 3 hours and it was my first time doing it i also took more of the dash out then i probably needed so the job could most likely be completed in two hours
Score 2
1 Opmerking:
I did not have to remove the steering column it's actually easier than what its made out to be
door Deel
To the best of my knowledge, there are actually 3 versions of heater core used in the 2004-2007 Caravan (Caravan, Grand Caravan) and I believe the main difference is the location of the hose connections. While I did not take photos, the only steps I needed to do on mine were:
Removed center dash cover (this is the section beneath the radio. 4 or 6 easily accessible Philips head screws)
Drop the brake pedal down (very easy. Remember to remove the brake switch first)
Remove the bolt on the steering column (basically splits the column into an upper and lower half. The top half stays in place and the lower half lays down (it is hinged).
Remove the screws holding the hoses and heater core in place and slide the core out (I used some aluminum foil to catch antifreeze that dripped out while I put some plastic wrap over the hoses and hose connetions (plastic wrap held in place with rubber bands).
Reverse the steps to reinstall.
This video is pretty good, https://www.youtube.com/watch?v=RLa-GlVf...
Take your time & you’ll do fine!
Score 1
1 Opmerking:
My 2005 Grand Caravan has a break/gas pedal height adjustment, the motor is between the heater core and gas pedal. The core Will NOT come out without moving the motor. the gas pedal, break pedal and height adjustment motor is all hooked together. Any 4-1-1 on that procedure?
door Deel
I was able to take the lower middle plastic section off and get the job done on an 04 Dodge caravan. The one I worked on had a tellascoping steering column with 1 screw that you pull out and the column collapsed and I was able to pull the core right out. Took 20 mins to pull out and put new one.
4 opmerkingen:
Sean... would it be that easy on a 2005 caravan?
door Deel
Yes, it's done exactly the same way.
door Deel
The Caravan has two different bodies (short & long), two different front heater cores and two different methods to remove the heater core.
Sorry I did not take pictures, but for my 2005 Grand Caravan SXT, I removed the bolt (with cotter pin) and lowered the steering column shaft to the floor, towards the driver seat (it is hinged at the floor). Dropped the brake pedal to the floor and removed the heater core. Plenty of room to do it all.
I had a shallow pail to catch antifreeze and a piece of cardboard as a funnel. About 3 cups came out of the lower hose connection on the heater core.
door Deel
The whole job took about 1.5 hours. Things to keep in mind are:
- the steering column bolt has a small cotter pin in the end. Pops out easily, then the bolt must be completely removed for the mid-column to separate from the upper column.
- Use something to plug the holes on the heater core (I used old wine corks). Fluid continues to drain out of that thing for awhile.
door Deel
Voeg je antwoord toe
John Byars zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 75
Altijd: 68,892
