battery contacts points missing in cover
how can I replace the battery contacts points in the cover
Is dit een goede vraag?
@fasteddywilson, edmund, Normally the battery door assy would be replaced as it will have the contacts molded into it I believe. Below is a guide that will show how to disassemble camera to access battery door hinge pin to enable changing of battery door. Also a couple links to replacement battery door assy. which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Canon PowerShot A620 behuizing vervangen
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 637
