Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor voertuigen geproduceerd door de Oldsmobile-divisie van General Motors (GM).
Having RPM gage issues
I have a 2002 Oldsmobile Aurora that I just bought 2 weeks ago. The check engine light was on when I bought the car but I wasn't having any issues.. It was put on the computer & it had a misfire code that came up. Then last week I went to start it & it immediately died.. I turned the key off & it started back up with no problem.. But my RPM's immediately went to 8 while I was sitting there waiting for it to warm up.. I didn't realize at first so I started driving.. Then when I came to a stop my RPM's was going down to 4.. That's when I realized what had happened..So I turned my car off & restarted it & then my RPM's were between 1 & 2.. It does this all the time.. Plus there has been a few times that I was driving & my RPM's were normal.. Then I give it gas & my car kind of jerks & my RPM's immediately go to 8.. So I have to stop to turn my car off & restart it again. My mechanic says that I need a crank sensor & that will fix the car from the dying issue.. But he is not sure why the RPM's do this.. Any idea's???
Is dit een goede vraag?
1 Opmerking
Misty Norris what is the exact code you got when it was scanned?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Misty Norris it absolutely can be the crank position sensor. Most common symptoms of a failed sensor are
Check engine light on
Cylinder Misfiring
Poor Acceleration
Intermittent Starting until it will not start at all once the sensor has failed.
This video will show your where that sensor is located on the 4.0 liter V8 engine (You did not give us your cars engine size) and for the 3.5L engine it's here
Afbeelding
Your vehicle seems to show all those symptoms. Go with what your mechanic suggest.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Misty Norris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 583
