Ga door naar hoofdinhoud
De LG X Power is een 4G LTE-smartphone die werd uitgebracht in augustus 2016. Dit model heeft een geheugen van 16 GB en een Android-besturingssysteem.
My touchscreen not working
I had my phone in my pants pocket and it had a case on it and it rained a little bit got my pocket wet a tiny bit and after I went on lunch for work my touchscreen wont respond I reset my phone but I cant click next to set it up
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
1 Antwoord
Filteren op:
try taking the phone completely apart, and checking all the connections and letting it fully dry out if it isn't.
make sure the touch screen is receiving power from the charging port. Let us know if this helps or if you find something, good luck!
You have to do an advanced hardware reset by first removing the battery for 30 minutes. Set a timer. After 30 mins, replace the battery and hold the volume down button for another 15 minutes. Set a timer. After 15 minutes, release the volume down and press volume up button rapidly 3 times and then immediately remove the battery again, this time, also remove the sim card. Wait about 30 seconds, and replace battery and sim.
When you power the phone back on, you should get a prompt asking you which hardware component to update., Select "screen sensor" by scrolling through the options with volume down and select it by pressing volume up. The phone will now reset the "screen sensor" hardware data and download the newest hardware update for your phone.
Screen should now be fully functional.
Was dit antwoord nuttig?
4 opmerkingen:
Unfortunately i cant take the battery when i try to it bends the nattery
door
I have this same phone. You can't take the battery out.
door
never heard of an "advanced hardware reset" ...
will try it now and report the result
door
Well, it's like i thought, not working
door
Voeg je antwoord toe
Jango DarkWind zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 25
Altijd: 6,043
