Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Screen glitch after water damage
So my partner dropped her phone down the toilet and thous the device now has water damage.
We done the usual, left it a good few days in a warm space in some rice and hey presto it came good other than a screen glitch and draining the battery.
Now I've had a good few iPhone device apart in my time and replaced components but I was looking for suggestions before doing anything with the iPhone 6.
I'm guessing a new battery is a given for the draining problem but any suggests on the glitch?
It appears to happen when the battery is very low or when the device is cold.
Is dit een goede vraag?
Score 1
4 opmerkingen
my phone dropped in the toilet i took it out as fast i can i opened it there was lines across the screen but they were like half visible too see and then i tried to reboot the iphone 6 but it kept doing a reboot loop so then i put it in rice please help me
door
Hold the power button and home button together that should fix the problem
door
My phone going up an down an I see two of the same things an my screen going up an down please help me
door
i was washing dishes and my phone got some water on it and i cleaned it off but it wouldn't stop glitching i cant power it off ,the home button doesn't work, and buttons don't work. What should I do?? I have already tried the classic rice trick.
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
Take out the logic board and follow this guide to clean it:
Electronics Water Damage
What do you mean by glitch? Is it lines, dark/light spots, etc.
Was dit antwoord nuttig?
Score 8
3 opmerkingen:
I'll give that a try thanks.
The glitches are as you said lines down the screen, screen jumping about the screen. This all settles when the battery is charged up fully and works like a dream, just throws a wobblily when low batter life.
door
Also, do not use the phone until it is taken apart and properly cleaned.
door
When i take showers i keep my phone in a bag so it doesnt get water damaged but today there must have been some type of whole in the bag and water got in it as soon as i realized it i ran to the kitchen and got rice when i took it out of the rice to see if it was helping the screen was black with purple streaks down the middle. PLEASE HELP ME
door
It is real,I accedantly dropped my 6s iPhone in the shower and it was a couples of hours in rice and the screening glitch stopped and my phone went back to normal
Score 1
1 Opmerking:
ive had my iphone 7 in rice for 2 days now and it still wont go away
door
I have left my phone in the bathroom while taking a shower. Will the moisture from the heat cause water damage? Ever since my phone has been glitching such as, going black (screen will turn black but the phone isn't fully turned off), freeze, go to the homescreen when I'm browsing apps. This has been happening for a couple of months. Went to some phone repair shops and they just said it was the battery? Is this false or true? Thanks.
This exact thing happened to me. After I got it out of the toilet, it started glitching with lines going up and down the screen. I put it in rice and left it there for a couple of days , and came back to it still not working. A day later I just gave up on trying to fix the phone myself and went to a specialist. He fixed the water damage and got the stuck rice out of the charger hole! I definitely recommend going to a repair place if all else doesn't work (even though going to a repair place costs a fortune).
1 Opmerking:
how much did it cost?
door
I put the phone in rice and it kind of help but the phone keep on glitching. the screen also turns white
Okay so I have a iPhone 6s and I went to camp. When I washed my hands I had a pipecleaner bracelet on and I accidentally put it on my phone in my lunch box when I took it off. It dropped water all over my phone and when I finally realized it (5 minutes later) my phone did the “You need to charge me” signal. So I thought it was okay. When I got home and charged it I tried to turn it on and it started glitching with a blue line running across the screen.. I was unable to take it apart so I just put it in rice for two days... when I checked it it wouldn’t even show me the “charge me” signal.. I am so dead...
So I went outside and I accidentally dropped my iphone into a bank of snow. I thought it was fine but the sound doesn’t work and Siri keeps popping up without me even touching my screen.. help.
(iPhone 7plus ) My phone accidentally fell in a puddle of water and now it has a long white line across the bottom and the left side of my screen is cloudy and gray , also it’s glitching too . What should I do?
so 2 days ago my baby threw up on me while he was asleep. i thought he only threw up on me but when i got up i saw that it also got on my iphone 6s plus. i picked it up as soon as i saw it and after a few minutes, everything started messing up. the speaker no longer works, the side button was not working nor the screen. the screen completly lost its touch. i cant use it anymore. i put it in rice for 2 days and now the side button works. the screen works sometimes but it freezes and wont let me use it. the speaker still doesnt work. what can be the problem? is it even worth replacing the damaged pieces and what should i fix? im thinking of maybe getting a new screen replacement but idk if that will solve the screen problem. please help!
Voeg je antwoord toe
Tino84 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 291
Altijd: 75,112
