Ga door naar hoofdinhoud
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
PSP not working after using it with a faulty cable
Hi, I have a PSP without a battery and was playing on it by having it plugged into a powerbank constantly. After some time, the psp started turning off when the cable was at a certain angle. It didnt happen very often, so I just ignored it, but after a while the psp stopped turning on, not even the green light would turn on. I thought the cable has shortcircuited inside, and so I checked 2 fuses on the motherboard with a multimeter, but they seemed to be fine.
Any help would be appriciated, thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Martin Sevela this "turning off when the cable was at a certain angle" sounds like your issue is with the power connector. To replace it or to check it, you'd have to remove the motherboard. Use this guide to get there. The connector would have to be replaced by soldering a new one to the board. that would also give you an opportunity to replace the battery.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Martin Sevela zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 227
