Ga door naar hoofdinhoud
Uitgebracht in juni 2005, herkenbaar aan modelnummer AL1916.
Monitor turns on and off
I read this article Acer AL1916 Troubleshooting
good morning my monitor is powering all right but the moment it comes for a while goes off. It does not blink on and off the monitor is on but the light is deem how can I go about it to make it appear clear and bright?
Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I had this problem. I opened the display, noted several heinous looking capacitors on the Poewr Supply board, Installed the correct replacements - haven't had a glitch from it in 3 years.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
[http://www.markdigital.com/wp-content/up...
Btw, just because a capacitor isn't bulging or leaking doesn't always mean it's 'Good'.
Hope this helps. It is very important to replace the removed devices with those of equivalent value, especially capacitance. Slightly higher voltage doesn't general make too much difference, never replace the device with a lower voltage specification otherwise it go boom.
Good Luck!
door
This is most likely an issue with the backlight. Try shining a flashlight on the screen after it goes black, can you still see the display? If so your backlight is going bad and your lcd is fine.
Voeg je antwoord toe
enockgyesi5 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 1,208
