Ga door naar hoofdinhoud
Deze iteratie van Amazon's Kindle Paperwhite-serie werd uitgebracht op 30 juni 2015. De Kindle Paperwhite 3e generatie is een 6-inch e-reader met een display van 300 PPI die beschikt over wifi. Het aangewezen modelnummer is DP75SDI.
Frozen unresponsive screen. Can it be repaired?
Hi!
I have a Kindle Paperwhite, 6" High Resolution Display (300 ppi) with Built-in Light, Wi-Fi - bought in October 2015.
Kept well, it hasn't fallen down, nothing untoward. Stopped working. The screen had an erratic display for a while, and has now stopped responding.
Can anyone help?
Is dit een goede vraag?
Score 4
1 Opmerking
I am having the same problem, could you find a solution for this? Please let me know.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
I had this problem with an e-reader and it turned out that it quit charging. After placing the e-reader on a new charger it started working again. The models we use in our school are all nooks but this may help you out too.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hey! Thank you so much. But this one is charging. No problems with that. Just that the screen gave an erratic display and then stopped responding. I am trying to understand if it is a screen or motherboard issue. Will try and fix it accordingly.
door
Did you find a solution to this? I am having a similar problem
2 opmerkingen:
... me too!!!
door
@skeeve205 could you please let me know if you found a solution for this?
door
Try tapping (or knocking with your nail) in the bottom right corner of the front. (Edit: you can also try bringing a magnet to that corner and bringing it away)
If it responds, then I have a workaround for this, that I’ll publish as a “technique” guide within the next few days. (EDIT: here it is!) The only problem with that guide is that it will no longer respond when opening/closing the cover
Voeg je antwoord toe
Anamika Das zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 5,233
