Ga door naar hoofdinhoud
How to get to the battery.
how do i take off the back so i can look at the battery? there's no
screws or anything!!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Charles Kinnison, Hopefully the link to the guide for battery replacement below will work for you(not your exact model). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Insignia Flex 11.6 Battery Replacement
Was dit antwoord nuttig?
Score 3
Taking the back off is not that difficult. I used a credit card to pry the back off by inserting and working around until it loosens up and off. Identifying the battery is another matter. There are two square plates (appx 31/2”x 5”) covered with white plastic. One showing part number and date, the other blank. The one with part # also shows a + and — which I assume could be the battery. I googled the image of the replacement battery for the tablet and the markings are shown differently than the part I described above. Also there's no visible detachable plug connector. I really can't be certain if what I am seeing is a battery. Maybe somebody reading this can help.
1 Opmerking:
What kind of SSD or Storage is on the device? Can I replace with something bigger and faster?
door
Voeg je antwoord toe
Charles Kinnison zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,562
