Ga door naar hoofdinhoud
Insignia Flex 11.6 Battery Replacement
Wat je nodig hebt
  1. Insignia Flex 11.6 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Insignia Flex 11.6 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Insignia Flex 11.6 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
  2. Insignia Flex 11.6 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 11.6 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
    • If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
  3. Insignia Flex 11.6 Battery Replacement: stap 3, afbeelding 1 van 3 Insignia Flex 11.6 Battery Replacement: stap 3, afbeelding 2 van 3 Insignia Flex 11.6 Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool, gently pry off the back cover.
  4. Insignia Flex 11.6 Battery Replacement: stap 4, afbeelding 1 van 3 Insignia Flex 11.6 Battery Replacement: stap 4, afbeelding 2 van 3 Insignia Flex 11.6 Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Battery Replacement: stap 5, afbeelding 1 van 3 Insignia Flex 11.6 Battery Replacement: stap 5, afbeelding 2 van 3 Insignia Flex 11.6 Battery Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire.
    • The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Donde puedo adquirir la batería?
arag12 - Antwoord
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
Robert Sandfort - Antwoord
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Hank Drabczak - Antwoord
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 4,812
