Ga door naar hoofdinhoud
Repair guides and support for top and front loading Whirlpool brand washers.
425 Vragen Bekijk alle
How to fix error code F08 or FOB
Washing machine starts up and after 2 seconds it stops and this code came up. Have to reset the washer cause the door locks. Ive tried various different loads and even a empty load but no luck.
Is dit een goede vraag?
Score 5
2 opmerkingen
fscr10420 error f08
door
I have had a brand new machine installed Friday the 10th,the very first wash came up F08,have phoned manufacturers and Indesit,,they have booked a appointment for 5 days,this should haven't happened as brand new.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
jmears83 , You did not state your model #. This is info i had come up with, F08 indicates that the heater is an open circuit. Check the heater wires for dislodged or burnt wires and check the heater for continuity with a meter.
Check the link below for further info. and view the video. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.espares.co.uk/advice/0/3521/w...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
hi
me i have replace the heater and the ntc at the same time the cable system is ok but the problem still going...what else i have to do???
door
I have the same problem. Replaced the heater, washer functions normally except for the error at the end of the washing when it shows F08. My brother also had the same issue but his machine was repaired at the shop. Mechanic couldn't figure it out (why it is still showing error) so he reprogrammed control unit just for that…
Score 1
1 Opmerking:
ok very usefull info but unfortunally here in company nobody knows how to reprogramming ,,,all says to replace the control unit and my friend this costs money ..(for nothing????).
door
Voeg je antwoord toe
jmears83 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 163
Altijd: 65,443
