Ga door naar hoofdinhoud
An all-in-one inkjet printer, scanner, copier series by HP. Model number CX042A.
31 Vragen Bekijk alle
Missing parts of document - tops of words and complete lines
My printer is missing the top parts of words, and also complete lines of text. I've tried renewing cartridges - even though the black one showed nearly a full cartridge., but the problem still persists. Any help would be appreciated.
Is dit een goede vraag?
2 opmerkingen
Thanks for your help. I had to carry out the procedure 3 times, but in the end I had a perfect result. Many thanks.
door
Your welcome! I'm glad I could be of assistance to you.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sounds like you need to clean the print heads. You can do this within the menu or, if you have the application do it from your PC. Also try aligning the printer.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Marjorie King zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 1,732
