Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Week wifi connection after battery replacement
I replaced my iPhone 6 battery a month or so ago, and ever since then my phone has been having trouble picking up wifi unless I'm very close (about 10 feet) away from the router.
The wifi is not greyed out.
I've also noticed some poor Bluetooth connectivity when I'm playing music in my car and so location issues with my Maps GPS since the battery replacement, but I don't know if these issues are related
Is dit een goede vraag?
Score 4
2 opmerkingen
I have the exact same issue!
door
The Apple Store replaced my iPhone 6 battery and now I have to be in front of my modem to receive a signal. None of our other devices have this problem so it must have been damaged during the replacement.
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
Sounds like you are having one of two issues. The first, and probabaly not likely is that the wifi antenna got unplugged or is failing. The second and more likely thing is that the wifi/Bluetooth chip on your motherboard is loosing its connection causing you to have a weak signal. In order to do this repair, you will have to micro solder a new chip onto your motherboard. Not the easiest of repairs that's for sure, but can be done.
Was dit antwoord nuttig?
Score 1
7 opmerkingen:
I find out sometimes that the L shaped antenna cable that plugs into the top left of the logic board can go bad like hard drive cables in a unibody MacBook.
Sometimes it's just screws needed to be taken in and out for the wifi antenna stuff.
door
I doubt the battery replacement caused this issue. It seems more of a coincidence that it happpened near the same time as the repair.
door
Well I had the same coincidence! My WiFi worked just fine until Apple replaced my battery!
door
I have same thing happen, Genius Bar respond me battery is not related to wifi antenna and they can’t replace it. They suggested me to replace phone on $439.
Don’t know what to do?
door
Dito. I just replaced my battery at Genius Bar and having WiFi problems.
door
2 commentaren meer tonen
You probably need a new wifi antenna. It is a common issue. Sometime it could be that it got unplugged
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable Afbeelding
Product
$9.99
Score 1
1 Opmerking:
https://cepmarket.com.tr/urun/iphone-wif...
Türkiye’de yaşıyorum bende de wifi sorunu vardı, bu firmada yaptırdım, şu an için sorun yok, dilerim bozulmaz
door
I have the same issue after replacing my battery and it always ended every month extra charge for my data…
I had/have this same problem and after tearing into the phone to investigate, found that I had accidentally broken the wifi/bluetooth antenna connector (the S-curve piece that connects the antenna to the logic board). I imagine this is an easy accident to occur during a battery change, especially if the adhesive doesn’t off easily.
1 Opmerking:
Did you fix it? How did you fix it?
door
Next day after 6s battery replacement wifi down load at 0.7 mbps says a speed checking website. Data via sim is 150mbs and wifi modem says should be above 40mbs.
Same here! Genius Bar Replaced the battery and now poor WiFi. Coincidence? I think not!
Score -1
1 Opmerking:
Go to Genius Bar and argue with them otherwise lodge the complaint formally and deal with them. I got new replaced phone on free, after fighting back for 2months.
door
Voeg je antwoord toe
Anna Spuhler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 7,292
