How to get data offbroken screen
I have 300 sound files I need off the phone but the screen is cracked beyond function. How can I get the data off?
Is dit een goede vraag?
Sibha Gourd, If not powering on because of screen, perhaps you could use the links below to replace your screen and get your phone up and working again and retrieve data. 1st link is a guide to show how to replace screen and the second link is a replacement screen assy. for as little as $15.99, which you may be able to do a search on and find for less. Good luck.
Was dit antwoord nuttig?
You will just need to plug it in in to your PC and go to the files of your mobile phone wich will show in the finder, like if it would be a USB.
You are welcome! :)
Yes, thank you I tried that and nothing shows up. What I learned was in order for that to work the phone needs to be set to "mass storage device" mode which is within the phones "settings" however I can't change the settings for obvious reasons. I need a remote way to change the setting or an app that knows how to access the data without that option being set or...???
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 331
