Ga door naar hoofdinhoud
De Asus ZenFone 2 (ZE551ML) is een Android-smartphone van ASUS die in maart 2015 is uitgebracht.
How replace power button
please help how i can repair button phone dont turn on
Is dit een goede vraag?
2 opmerkingen
I need help to find where to get a new power bottom for Asus Zenfone 2
door
You can get it on Aliexpress.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2-moederbord vervangen
Was dit antwoord nuttig?
Score 2
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Score -1
1 Opmerking:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
door
Voeg je antwoord toe
Anton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 4,258
