Ga door naar hoofdinhoud
2.3L 4cyl or 3.0L V6, 6th Generation
20 Vragen Bekijk alle
Dash lights and tall lights not working
1999 honda accord
The wires to the radio got cut so there is no longer a radio, since these happen the tall lights,and dashboard lights don't work
Is dit een goede vraag?
Score 2
1 Opmerking
Thanks Jay but yeah all the fues are good. I'm wondering if there is a ground wire that got disconnected
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi Brock,
Found this link which may be of interest to you.
Whilst not exactly the same problem as yours it has a similar feel.
See post #6
Hopefully the multiplex unit in your car was not affected when the radio wires were cut.
http://www.hondaaccordforum.com/forum/ge...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hi,
Check the fuses for the tail lights/dash lights.
It might be that when cutting the radio's 'illumination' power lead, it blew the dash/tail light fuse. (usually radios have two power supply feeds, i.e. power and 'light')
Just a thought.
door
Het nuttigste antwoord
Brock Eiler , Just in case! Recheck ((all)) your fuses very carefully again, under hood and interior box, possibly a 10A fuse in interior fuse box blown. Good luck.
Score 2
1 Opmerking:
I need help with my 1997 Honda Accord my tail lights don’t work at night and keeps blowing the fuse under the hood
door
Voeg je antwoord toe
Brock Eiler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 12,843
