Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone is not booting. Screen flickers
Hi.
Have a problem with an iPhone. It won´t boot. When it tries to boot the screen suddenly flickers in many colors and then reboot.. It does this two times, and after that it´s not possible to turn it on before the battery is disconnected and reconnected.
I have tried several (original) screens and batteries. Anyone know what might cause this problem?
Here is a video showing the problem:
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
What model iPhone? The 5 and 6 gens can be damaged by installing the screws in the wrong place causing damage to the motherboard. You would need a microscope to see it. You can search "Long screw damage" or "blue screen of death" (BSOD) to see more symptoms and causes. The only repair for this is highly skilled trace damage micro soldering which very few repair shops can perform.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I've put it under a microscope today, and there is no damage on the motherboard (where the screws are)
door
It looks like you might have damaged the logic board try checking the logic board to see if possibly chipped any parts.
Voeg je antwoord toe
alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 519
