Why does seat belt not latch?
Seat belt won't latch
Is dit een goede vraag?
@bigredd , Todd Rediger, If you do not see any obvious obstruction inside the buckle that you can picked or blown out and the opposite (latch) end is straight/undamaged, it is recommended to replace the defective part for safety. The buckle lock tab/spring could be worn/damaged inside and are not meant to be serviceable. You could order a new replacement or check out the local auto recycler for the part as it would be low cost from them. Video link below may be of some help with belt replacement or if not wanting to do repair yourself, take into a good shop, have them take a look and estimate repair. Good luck.
Was dit antwoord nuttig?
The seatbelt latch can be quite easily taken apart with a screwdriver or butter knife. I took mine apart on a 2007 Mustang and found a very small plastic piece that theyu put tags on clothes with lodged in the buckle. You could not see it until the buckle was uncovered. Pulled it out and snapped it back together and all works great.
I sprayed mine with WD 40 in the opening on the top, and works fine now. Guess it was just dry.
You need to give more details
1. Check if there is anything blocking the "receptor".
2. Check if any parts are broken
You did not say which seat belt will not latch, if there are 3 seat belts in the back seat, the center seat will not latch into the other receptacle adjacent to it, sometimes its own receptacle is pushed down into the seat and you don't know that you are trying the neighboring receptacle, they are designed that way to not latch into the wrong receptacle.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 19,988
