Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor 27-inch Intel iMacs van Apple, geïntroduceerd in oktober 2009.
3405 Vragen Bekijk alle
iMac 5K Late 2015 SSD Replacement Troubles with Step 35. Urgent help.
I was following this guide on disassembling my Late 2015 iMac 5k 27".
iMac Intel 27" 5K Retina-scherm Vervanging van de blade SSD
I got to Step 35 to remove the 4 T10 screws. I have the Classic Pro Tech Toolkit (before the revamped one came out) and I was trying to remove the bottom right 7.3 MM T10 screw, but have not been able to give the screwdriver enough torque to get it out. I have tried many many times trying to get this screw out, but it is really in there. I ended up stripping the screw (by using so much force) and ruining the T8 head that came with the toolkit (although it says it's a T10 screw, it's actually a T8 because the T8 fits like a glove).
I am completely lost on what to do. I was trying to disassemble the iMac to fit a blade SSD in there and was not expecting to encounter a problem like this. I use this computer at work so I screwed myself over a little.
If anyone kind enough could please advise me on what I can do to rectify the issue I would sincerely and greatly appreciate it.
Thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
A large jewelers pin vise should be able to clamp on the external wall of the screws head.
You'll likely need to use a large soldering iron (50 watt) or heat gun to heat the screw to soften the thread seal which they use.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Federico Olmedo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 116
