Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor de EOS 70D, een spiegelreflexcamera die in 2013 door Canon werd uitgebracht. Deze camera is te herkennen aan het modelnummer DS126411.
Sd card reader not working
Man sd card got stuck in the camera. When it got pulled out a little piece broke now it says the sd card is locked even though its not.
Is dit een goede vraag?
1 Opmerking
Nothing wrong with my card. My card reader of the camera not reading cards
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
A little piece from where, the SD Card or the camera?
Most SD Cards have a sliding lock switch. Is this missing from the SD card?
Afbeelding
(click on image to enlarge for better viewing).
If so replace the SD Card.
If the part is from the camera, as I cannot locate a service manual online, here is a link that shows how to replace the LCD screen in the camera. Hopefully it contains enough information for you, about opening the camera, so that access to the card reader is possible for it to be replaced.
https://www.youtube.com/watch?v=N4jD6_6R...
Here is a link to some suppliers of the card reader (if that is the problem). It is not a recommendation to use any of the sellers. It is just shown to give an idea of the cost of the part.
http://www.ebay.ca/sch/Replacement-Parts...
To replace the part, you will need the requisite SMD (Surface Mounted Device) soldering skills and tools. It may be cheaper in the long term to take it to a reputable, professional camera repair service and ask for a quote for a repair.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Christian Morales zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 25
Altijd: 1,993
