Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie en probleemoplossing voor de 7" RCA-tablet uitgebracht in 2014, te herkennen aan modelnummer RCT6773W22.
Reset to factory settings
Is dit een goede vraag?
Score 3
1 Opmerking
My a
Rca keep asking for the gmail that was on tablet before how do I get passed that
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
Go to Home > Settings > Personal > Backup and Reset and see if there is an option there to do a factory restore or reset.
Be aware that this will erase all your user data and downloaded apps. It will restore the tablet to a factory default condition.
Ensure that the battery is fully charged before performing the reset and that the external SD card (if any installed) is removed. Do not perform the reset with the charger connected.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
How do you do a factory reset, the tablet is frozen at the power up screen. I can't get it to shut off or change screens to do the factory reset
door Deel
I have the pass code but I can't undo the factory reset
door Deel
I am having a problem with sign on Passover.. I can't get past it to change it.. None of the rest suggests are working.
door Deel
It won't let me past screen lock to access anything on the tablet.. I can't go to any settings or anything
door Deel
door Deel
Voeg je antwoord toe
daniel sunstrum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 1,109
