Ga door naar hoofdinhoud
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
20 Vragen Bekijk alle
My daughter spilled coffee on keyboard
So my daughter spilled about 1/4 cup of coffee on my keyboard. While on panic mode trying to clean up the keyboard I accidentally unplugged the ac power cord. It does not have the battery since at home I usually use my laptop on the ac power. I worried more about the keyboard and cleaning so it "wouldn't absorb" that I didn't turn upside down right away. Nor did I bother to look up online on my phone to see what to do. When I thought I had cleaned keyboard I plugged in the ac power thinking problem was solved, as soon as I plugged it in their was a loud beeping sound. Dumb me, I decided to press power button off and then on again. I did this about 2 times and then decided to unplug power cord. When I noticed their was some coffee coming out from under laptop. Not a lot, but some drops here and there. Does this mean my laptop is done or is there still some hope???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@yesenia_s ,Yesenia S. There is always hope! Do not try to power up the device any more, you may have already caused a short by doing so, you have to dismantled and clean liquid damage. Use the first link below, a guide to tear down your device and the second link is a general guide on how to clean up liquid damage/corrosion. The better job you do at cleaning the device, better odds of getting it up and running. Good luck.
Dell Inspiron 1545 Motherboard Replacement
Electronics Water Damage
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Yesenia S. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 7,694
