Ga door naar hoofdinhoud
unable to adjust screen brightness
i am trying to decrease my laptop's screen brightness but i can't because i did not find any option for brightness.i have tried several times by the help of google and youtube but they didn't work. how can i fix this problem?
Is dit een goede vraag?
Score 2
1 Opmerking
Does your keyboard have brightness buttons?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
if you have windows right click the desktop and go to personalize, then you go to display and on the left hand side there should be an option to adjust brightness. I hope this helps and that you are able to brighten your screen and you day!
Was dit antwoord nuttig?
6 opmerkingen:
the options for brightness are also in the power settings
door
which version of windows do you have? and are you able to take a screen shot
door
also did you check you power setting?
door
it's windows 10. and it's been working after I updated windows :)
thanks
door
1 commentaar meer tonen
Het nuttigste antwoord
acer laptop sucks…… worst laptop ever….
s*it…..full of f#ck……………bulls*it
brightness not accessable… cant start dual boot… full of problems
Score 1
no brightness setting, Fn + > does not do anything. Fn + ^ does do volume per key but no brightness? No setting in Win11 either. weird . Win11 "No result for screen brightness" way to go MS! Booting to faster Linux....
Voeg je antwoord toe
zarinraiyanoroni zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 11,071
