Ga door naar hoofdinhoud
Repareer uw Dyson DC 14 stofzuiger met een reparatiehandleiding voor onderdelen.
Reassembly of brush orientation
I quarter turned the screws and exposed the roller brush to remove built up pet hair.
When I reassembled it, the DYSON DC14 turns on but the brush roller won't rotate and their is no bottom suction.
The extended wand has suction all of the time but not the power head.
I may have disoriented the endcaps on the roller bar and would like to know proper placement.
Also, why no suction there now and how do I fix that?
Debra R
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
ruthdebra55 , Sounds like the hose/channel to the power head may be plugged, remove power head brush and see if suction port clogged and also make sure canister is locked into position correctly. Find below a guide on the power head that shows orientation. Good luck.
Dyson DC14 Borstelrol vervangen
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
No clogs (anywhere), proper assy (thanks for that) and still brush does not rotate.
It rotates manually without any extra tension and the belt seems fine.
door
ruthdebra55 , Thanks for replying back. Just a thought are you turning the brush control to the on position? There are 2 belts that drive the brush, the brush belt and the clutch belt. I will post a video showing how to change both belts along with a link to your manual for the DC14 which shows how/where to check when loss suction. Good luck.
https://www.youtube.com/watch?v=7_CtaFcc...
http://media.dyson.com/downloads/us/floo...
door
Voeg je antwoord toe
ruthdebra55 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 5,451
