Digitizer connectors broken, solder pads on board damaged
When replacing the digitizer, the connectors came apart. I had a gentleman in Kentucky check it and he planned on placing jumper wires from the test points to the connectors.
The repair was only partly successful. Some of the wires are broken. I don't know if it was in shipping or what, and its irrelevant to me. I am an experienced Electronics repair technician but am a bit out of practice, especially with micro soldering.
I would like to give it a go, but I need a diagram showing which test points connect to which pins on the connectors.
I have the schematics, a good work bench, some dated but very functional equipment, and would love to try.
Can you help?
Is dit een goede vraag?
1 Opmerking
@novaguy start by posting a couple of good images of your repair, damage, pads etc. with your question. That will allow us to see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag to post some images.
door oldturkey03
