Ga door naar hoofdinhoud
Draagbare luidspreker met draadloze verbinding en ingebouwde microfoon. Uitgebracht op 27 januari 2014.
Audio is not clear
Im using JBL flip 2 since an year recent days it is getting disturbance sound when the volume is high.I can even see a little opening at one side of rubber tube . Please suggest me ways to fixit.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
Here is a link to the ifixit guide on how to replace the speakers, in your Flip 2.
It is handy as it shows how to gain access to the speakers to see if they are not secured properly and it is the actual speaker assembly that is vibrating at high volume (when it shouldn't) or if there is a loose connection etc. on them which may be vibrating when the volume is high thus giving the unwanted sound.
Check to see if you can determine which end of the speaker the problem seems to be coming from so that you know which end to look at first when dismantling the speaker.
JBL Flip 2 Speaker vervangen
Was dit antwoord nuttig?
Score 1
1 Opmerking:
How much money to replacemet speaker jbl flip 2 ?
door
Voeg je antwoord toe
Bhaskar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 2,771
