Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Managed to make my battery spark/short
My battery needed replacing on my iphone 6. I ordered a new one and followed a good Youtube video on how to replace it. Anyway I got to the part where I had to remove the battery and like an idiot I used a flat bladed screw driver and tried to pry the battery away from the glue (I removed one row of glue using the tabs). Anyway a small spark (almost like when you initially light a match) came from the battery then died down, then appeared again 20 seconds later. I quickly put the phone in a sealed bag, into a metal tin and now its outside.
What I want to know is, should I attempt to carry on? I don't want it to explode and potentially hurt me, or should I just bin it (properly) and buy a new phone? Thanks for the help in advance.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Assuming your phone hasn't entirely combusted in the bin ;>)...
Follow this guide, specifically steps 20-24 on how to remove the battery safely. There are special pull tabs for safely removing a battery. Ideally, you should install new battery adhesivewhen you re-install a new battery.
iPhone 6/6s/7 Battery Adhesive Strips Afbeelding
Product
$3.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Ok, thanks. I was trying to fix my screen and I hit it down because I'm a mong and the metal from the screen hit the battery, if I'm correct, there's 3 layers on the battery and I got through the last one but the spark died down, it didn't smell nice at all and I $@$* myself when I saw the spark and I put it on the wooden table and moved everything flammable away like paper, my wallet and all that. What will happen if I plug it in now? I am very curious but if it blows up I don't want my entire phone to catch flames and have to get a new one, I'm guessing I either broke the battery or shorted it big time. Poor IPhone 6
door
Het nuttigste antwoord
It won't explode, it just burns and releases toxic smoke, no big deal.
Score 1
1 Opmerking:
Yea...the match burning analogy makes me think he just popped the battery. Should be fine. Nothing I would recommend doing on purpose but it happens and I've certainly done it.
OK...I just did it last week. FINE! ARE YOU HAPPY?
door
I've donethat on a 5. I just worked quickly to remove the battery
unless it is still plugged into the phone then you could short out / burn the connectors
Voeg je antwoord toe
Dan Clio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 5,413
