Ga door naar hoofdinhoud
Bread baking machine from 2006 or 2007
1 Vragen Bekijk alle
How to access timing belts
How to remove the covert to the timing belts on a BBA 2865 breadmaker machine
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Belt is at the bottom of the machine.
You need to:
  1. Remove the inner heat shield. It has 8 screws at the bottom and one on the side wall which is holding the heater. Remove it gently.
  2. Remove the top of the machine. Do not need to remove the lid. Just open it, remove the screws caps beneath the lead. There are 5 screws. Unhuk 7 plastic hooks just below the top.
  3. Remove base with the circuits, motor and heater. Unscrew all 6 screws. Remove GND (green and yellow) wire. Disconnect mains power connector from the circuit board. Gently pull out the base, watch for the on/off button.
  4. Remove the broken belt or wheel. Replace the belt or wheel.
  5. Put everything back in reverse order.
Was dit antwoord nuttig?
Score 2
Update (03.12.2022)
It cost me a lot of nerves to get the white plastic clips off. They are also a pain to clip back on later.
So finally, here the top is off, ready for the white plug to be unplugged:
The earth cable still has to come off:
Now take care of the on/off switch:
The switch cables can stay plugged in. Mine were so hard in, I feared to break them off. Just be careful.
Important for later assembly: the three spacers.
Now the way is clear to replace the timing belts.
Fixed. View from underwards:
Good luck! ;-)
Score 2
Voeg je antwoord toe
Pat zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 712
