Ga door naar hoofdinhoud
Manufactured by Dell Inc., this is a 19 in LCD monitor / TFT active matrix with a native Resolution of 1280 x 1024 and an aspect Ratio of 5:4
5 Vragen Bekijk alle
when I power on my monitor the lights goes off after a short while,
when I power on my monitor it lights goes off after three to five seconds, I can still see words behind the dark screen, what could be the problem ??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@ndubz that is a common issue with this model. The capacitors on the power board most likely have failed, causing the backlight to turn off. You can replace those or replace the board if you are not sure about soldering. Use this guide to work on it. If you need to double check it, post some good images of your power board with your question. For that use this guide so we can see what you see.
Dell 1908FPb monitor power supply Afbeelding
Handleiding
Dell 1908FPb monitor power supply Replacement
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
iFixit Afbeelding
Handleiding
Voeg afbeeldingen toe aan een bestaande vraag
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Was dit antwoord nuttig?
Score 4
1 Opmerking:
I thought about replacing capacitors but I was not sure about it though after power on there was some noise coming from within the capacitors. now I know what to do, thanks alot
door
Voeg je antwoord toe
ndubia zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 323
