Ga door naar hoofdinhoud
Canon PowerShot A-serie compactcamera uitgebracht in 2006, met een 6,0 megapixelcamera en een 4x optische zoomlens.
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
Afbeelding
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
Was dit antwoord nuttig?
2 opmerkingen:
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
door
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
door
Voeg je antwoord toe
John Darago zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 676
