Ga door naar hoofdinhoud
De HP Split x2 is een 13" hybride tablet/laptop-combinatie die medio 2013 werd verkocht. De HP Split is eenvoudig te herkennen aan het ontwerp waarbij de onderdelen uit elkaar getrokken kunnen worden.
How do I fix my split x2 touchscreen
I mistakingly dropped my split x2 and the touchscreen got a crack, the screen still display fine but the touchscreen is not working. I can only use it with the dock and not as a tablet again. Pls where can I buy the touchscreen and how do I fix it
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
You may be out of luck.
Here is a link to the service manual for your laptop. Hopefully I have got the correct one.
http://www.hp.com/ctg/Manual/c03958968.p...
It shows that the touchscreen is part of the display panel and not a separate item. Scroll to p.17 &19 to view parts and part numbers. It also shows that the touchscreen board (not the 'screen') is not available as a spare part so hopefully it is OK (part #9 on p.17)
If you search online using just the part number of the display you will get results for suppliers of the part.
Below are just some examples, you might find others that suit you better. They are only shown to give you an idea of the cost depending on what type of display you have.
This is for a WVA display.
http://www.ebay.com/itm/LAPTOP-LCD-LED-S...
This is for a UWVA display
http://www.ebay.com/itm/HP-Split-X2-P-N-....
The service manual shows the necessary pre requisites and procedures for replacing the screen.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Kayode zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,041
