Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Screen displaying weird lines (See Pictures)
Hi there! My screen is unresponsive and it is also showing weird lines on it. I tried disconnecting the flex cables and reconnecting it with no avail. The screen is not cracked or damaged externally.
Thanks everyone!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try a new screen if you have tried reconnecting. Usually blocks of lines can appear if the touch is not plugged in properly or recognised. Check the connector on the board also.
Was dit antwoord nuttig?
Score 2
Looks like your LCD went . I would try a new screen assembly. If re seating your cables didn't work , then looks like the LCD went out
Voeg je antwoord toe
Alvin Lee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 1,128
