Ga door naar hoofdinhoud
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
How do I replace the transmission
I need to know how to remove the transmission in a 2003 Nissan Altima 2.5 liter 4 cylinder and replace it with a new one are used1
Is dit een goede vraag?
2 opmerkingen
Is this the 5 speed manual or auto transmission.
door
Where the shift control box is on a 2003 Altima
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi Lamont!
You might find the answer on this question helpful:
auto trans remove and replace
Was dit antwoord nuttig?
Score 2
Hi @ Jr Brantley,
Here’s a link to the automatic transaxle repair section from the service repair manual for a 2001-2002 Nissan Altima.
Scroll to p.AT-15 to view the location of the TCM (transmission control module) if this is what you mean.
It is in the same location for a 2004-2005 Nissan Altima so presumably it will be the same for the 2003 model.
Score 1
Voeg je antwoord toe
Lamont zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,123
