Ga door naar hoofdinhoud
De Moto G4 Plus is een verbetering van Motorola's Moto G4. De Moto G4 Plus biedt een vingerafdruksensor, een grotere geheugencapaciteit en een verbeterde camera achteraan. Modelnummer XT1642 en XT1644.
moto g4 plus Micro USB Replacement
Can you put up a video on how to replace the micro usb port on the moto g4 plus?
Mine had the plastic literally melt after connecting in to an apparently faulty car charger.
Much Thanks and keep up the great videos!
Is dit een goede vraag?
Score 5
4 opmerkingen
Your phone didn't warn you what was happening?
door
Hi, did you solved this problem? I need to replace my charging port too.
door
Nope, ended up sending it in on warranty and getting a new phone.
door
Hi
I purchased a rebuilt Moto G 1st generation smartphone but the charger port was broken after I paid for it , and before I received it.
Can you provide an instruction manual or video? I have seen one but the soldering alone I know is more than I can do myself. Can you help?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
william_oliveira87, John Linden, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a USB charge port attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=8jqw-KwC...
https://www.youtube.com/watch?v=Bl_6g4GV...
http://www.ebay.com/itm/2X-Dock-Connecto...
Was dit antwoord nuttig?
Score 7
Voeg je antwoord toe
John Linden zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 10,942
