Ga door naar hoofdinhoud
Reparatie-informatie voor de Nintendo 64-controller, modelnummer NUS-005. Deze controller werd uitgebracht in 1996 voor gebruik met de Nintendo 64-spelconsole.
Analog stick - Nintendo 64 Controller
Hi all,
My analog stick of mine controller is not working fine anymore. I found replacements on the internet. I found 2 different version.
Afbeelding
I got version A in my controller. Can I solder version B in my controller?
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
From a bit of quick research, it appears that it should work fine. Just make sure that your pin connectors line up. Beyond that, it looks like it'll be okay to swap them out.
Best practice would be to install the new thumbstick and before closing it up, test out the controller to ensure that the new thumbstick reacts properly to the game.
Was dit antwoord nuttig?
I'd say it's a bit risky to add one of those into your controller, because if you got a warranty for it (IF YOU ONLY GOT IT A SHORT WHILE AGO that is) you have to hack into your controller to install the analog stick, and opening it up usually voids the warranty. Also, I've heard that the replacement analog sticks aren't exactly the best. Look in the video below
https://www.youtube.com/watch?v=o3GYtAyR...
Voeg je antwoord toe
Uas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 23
Altijd: 1,165
