Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
1.5 Core Solo-, 1.66- of 1.83-Core Duo- of 1.83- of 2 GHz Core 2 Duo-processor. Dit dekt de eerste op Intel gebaseerde Mac mini-modellen van begin 2006 tot medio 2007.
Anyone found an alternative Mac Mini outer casing?
Hi! I recently acquired a 100% functional Mac Mini from a recycler, the only catch being that the outer casing has been destroyed, and so the guts of the Mini are exposed, and it's not really in re-saleable condition. I've looked into replacing the casing, but it seems a little silly to spend $50-$100 that people are asking.
Does anyone have thoughts on a practical alternative to Apple's Mini case? I'd prefer something on the practical/discreet side, as opposed to goofy and outrageous.
Thanks!
Is dit een goede vraag?
Score 1
1 Opmerking
If you end up with it in the cube case or the floppy disk drive, you should take some pics and link them here so we can take a look at what you did.
door Deel
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
How about a nice ammo box. Lay it on its side, cut the top for the CD drive. Larger boxes could be used for extra hard drives. Comes with a carrying handle.
http://www.amazon.com/Military-Ammo-Wate...
For a bigger box, use the 50 cal version: http://www.amazon.com/Military-Surplus-C...
Here's a bunch of various goodies: http://www.colemans.com/ammocan.htm
Consider using the dome from a iMac G4 with out the screen attached.
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Or an old mac cube case would be awesome! but the little research I did I couldn't really find one for much less than $50.
door Deel
Awesome idea Mayer! I'm going to seriously consider it...my only concern is that the metal might keep wireless from working, but I'm sure there are ways around that.
R Trent, thanks for the idea...I have an old Cube around, so I'll see if it fits...that would potentially be a fairly easy solution.
door Deel
good answer +
door Deel
Yeah WL might be an issue- also it'd add a TON of weight, probably not good for ventilation either though, do you have a CNC machine?
door Deel
The cube's a great idea- in fact, it's upgrading the Cube so you get some sort of Mac Cube? Cube Mini? Whose origins cross processors and years.
door Deel
1 commentaar meer tonen
Here is one that mayer came up with on Meta that I really like.
http://www.pcworld.com/article/170973/co...
Score 3
3 opmerkingen:
Oh wow, that is amazing!!! I just finished putting it into a Cube case, but I think I'm going to buy an Apple floppy drive on eBay now, cuz that's just too cool to not try! :-) Thanks!
door Deel
legitt +
door Deel
+ I forgot about that one. It's good.
door Deel
How about buying a cheap generic mini-pc case? You can also often get those with a built in power supply, which is useful.
Score 1
3 opmerkingen:
For example, a quick eBay search turned this up, I'm sure you could get much cheaper with more thorough searching, and for Used as opposed to New parts
door Deel
door Deel
Great idea Rab! I'll take a look.
door Deel
Duct Tape
Score 1
1 Opmerking:
I like the idea, but wouldn't that run the risk of making the computer overheat?
door Deel
Voeg je antwoord toe
rdklinc zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 4,844
