Ga door naar hoofdinhoud
Down jackets wrap you in soft warmth, insulating your core from freezing temperatures and wind. They are highly compressible, extremely lightweight for their warmth, and ultra-comfortable for all day use.
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
Is dit een goede vraag?
2 opmerkingen
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
door
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Here's the guide on zipper repair for the Patagonia:
Installing A Main Zipper In Your Patagonia Down Jacket
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
Score 2
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
Score 1
Voeg je antwoord toe
villemitikka zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 87
Altijd: 6,850
