Ga door naar hoofdinhoud
The Fitbit Surge was released in 2015 and is identifiable by model number FB501BKL. This is a smartwatch that is capable of monitoring your heart rate, pace, elevation, and distance.
Why won't my battery charge?
My battery doesn't seem to be charging. I think it is plugged into the charger properly, what else could I do?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
My fitbit is not charging.
Was dit antwoord nuttig?
Score 2
If your charging cable is securely plugged into your device and it is still not charging, the USB port may be faulty. Test your computer’s USB port by inserting a different device into the port and checking it if is functioning. If the port is faulty, plug your charger into a different port or a different computer.
Score 1
I don't know . Someone tell me what to do .
Score 1
1 Opmerking:
I have found an easiest way to charge fitbit charge 2.. check it out..
https://technoradars.com/how-to-charge-f...
door
Voeg je antwoord toe
Angela Pitts zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 1,528
