Ga door naar hoofdinhoud
De Samsung Galaxy S5 Neo (SM-G903F) heeft een 5,1-inch Super AMOLED-scherm met Full HD-resolutie. Hij is uitgerust met dubbele camera's: een 16 MP-camera aan de achterzijde en een 5 MP-frontcamera. Hij beschikt over een 64-bit Exynos 7580-processor, 16 GB intern geheugen, 2 GB RAM en een 2800 mAh-accu. Het toestel meet 142 x 72,5 x 8,1 millimeter en weegt 145 gram. Vergeleken met de originele S5 heeft de Galaxy S5 Neo verbeterde specificaties zoals een betere frontcamera, FM-radio en snellere LTE (Cat6).
How do you get into this thing
AAAAAARRRRGHHHH
Someone help how the heck do you get into this thing?
this has turned into a nightmare I'm replacing the dock port on this I've already busted the screen (glass just came straight off the LCD but thats a whole different story)
I have also removed the 13 screws from the frame under then screen but i cannot get all the casing off the other side to get into where the motherboard & dock port is.
I have undone the clips on the inside of the battery recess but it all is stuck down tight i don't want to force it too much this repair has already cost me big time
Someone PLEASE help & point me in the right direction
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@inthebox ,Kenny, Link to partial tear down of the S5 Neo and a 2nd link which may have more info., Good luck.
Samsung Galaxy S5 Neo scherm vervangen
http://www.sonymobilephones.com/samsung-...
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Hi Thank you for that i did see that but it only goes as far as taking screen out not going in as far as getting motherboard out. Someone was kind enough to come & show me how. Its deceiving it looks like it should come away from the outer frame thats what i was looking at & couldn't figure it out it actually comes apart inside.
door
@inthebox ,Kenny, thanks for posting back, happy to here you had success with your device. Have a good day.
door
Voeg je antwoord toe
Kenny Leonard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 551
