Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Display striped and 1/2 toucvh screen does not work
The phone was dropped. exterior not damaged.
The display is now striped vertically. The displayed images move underneath the stripes, which are broad and translucent. Image under the stripes there appear washed out.
On the right side there are narrower, darker stripes. Also on the right side the touch function does not work.
Is it likely at screen replacement would cure the problem?
Is it likely that some connection or other repairable problem resulted from the drop?
Suggestions as to how to proceed.
Thank you
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hello, this is most likely just a damaged LCD and should be easily fixed by replacing the LCD.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Should just be a bad display.
iPhone 5s scherm vervangen
iPhone 5s LCD and Digitizer
iPhone 5s LCD and Digitizer Afbeelding
Product
$39.99
Score 2
Voeg je antwoord toe
Gary Tash zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 49
