Ga door naar hoofdinhoud
The second-generation (Mk 2) Ford Focus was launched in 2004 as a three- and five-door hatchback and an estate variant.
37 Vragen Bekijk alle
Strech fit serpintine belt replacement
Hi can someone please tell me how to replace my serpentine belt it's a 2009 Ford Focus 1.6 petrol I need to remove the small belt in front of the serpentine belt how do I do it
Thanks in advance Mark
Is dit een goede vraag?
4 opmerkingen
@powellkop this is a European version of the Focus?
door
Hi it's a UK car it's Baffing me I've never come across this problem before
door
@powellkop any chance you can post a couple of images of what you are looking at? The "smaller belt" confuses me.
door
If there is no tensioner it is a stretch fit belt and your main belt might be also,its best not to reuse it but you can get a tool to remove it in one piece if you do want to for £10 on ebay or use the cheats on youtube
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@powellkop , Mark, the video below may help. Installing stretch fit belt Ford Focus. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check
https://www.youtube.com/watch?v=wRkzBqM4...
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
It most modern vehicles you have to have a special tool to install stretch fit belts . Here is a link to one.
https://www.amazon.com/Lisle-59370-Stret...
Score 2
Voeg je antwoord toe
Mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 9,507
