Ga door naar hoofdinhoud
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Vragen Bekijk alle
MacBook Pro mid 2014 como consertar
macbook pro retina 13 A1502 mid
bom dia, tenho um macbook pro retina A1502 de 2014, caio de uma certa altura e ficou com o ecram danificado, usei algumas vezes com o cabo HDMI so que dava erro na imagem e desligava-se, então tentei formatar acabei por eliminar o sistema dele ja tentei voltar a ligar para tentar recupera mais quando vou tentar fazer a combinação de comando R+P faz um ruído no teclado e quando liga normal aparece uma caixa de envelope com o ponto de interrogação ou vai dando os 3 beeps. será que tem conserto o que devo fazer?
Is dit een goede vraag?
Score 1
3 opmerkingen
MacBook Pro mid 2014 how to fix
Good morning, I have a macbook pro retina A1502 of 2014, I fell from a certain height and got the damaged screen, I used a few times with the HDMI cable, which gave an error in the image and it was turned off, so I tried to format it, I ended up eliminating the system I already tried to reconnect to try to recover more when I try to make the combination of command R + P makes a noise on the keyboard and when it turns on normal appears an envelope box with the question mark or goes giving the 3 beeps. Is it okay to do what I have to do?
@danj another 3 beep machine with non-removable RAM. It's something else.
door
@mayer how about a reflow of the memory? Possibility of cracked colder solder joints?
door
@oldturkey03 I believe we are seeing this after the Sierra upgrade. I suspect it is software related or a manufacturing defect. But I do not remember it happening until after Sierra. Will have to do deeper research, I've looked for it before but found nothing but the old RAM (removable problems). I think this is something new.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Vimos vários MBP na faixa de 2014-16 com o mesmo problema. Normalmente, os três bipes seriam um problema de RAM. Uma vez que a RAM não é removível eu acredito que esta é outra coisa. Dê-nos um par de dias para pesquisar este problema e vou tentar contactar alguns membros da Apple para ver se podemos encontrar uma resolução.
We've seen several MBP in the 2014-16 range with the same issue. Normally the three beeps would be a RAM issue. Since the RAM is not removable I believe this is something else. Give us a couple of days to research this issue and I'll try to contact some Apple insiders to see if we can find a resolution.
Was dit antwoord nuttig?
Score 2
obrigado pela atenção mayer,fico esperado alguma resposta que me possa ajudar.
@fakikas Osvaldo! Encontraste solución ?
Voeg je antwoord toe
osvaldo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 648
