Ga door naar hoofdinhoud
Deze netbook, uitgebracht in juli 2008 door Acer Inc., kan worden geïdentificeerd binnen de ZG5 Acer Aspire One-familie aan de hand van het modelnummer A150-1672.
My computer is frozen and unresponsive.
Randomly my computer froze and the mouse won't move on screen. I can't pull up the task manager or get anything to happen. When I press the power button, it will go to a black screen, but when I hit it again, it comes back to the same frozen screen.
Is dit een goede vraag?
Score 2
2 opmerkingen
student question
door
My CP is stuck frozen how do I get it unfrozen
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
The computer may be taking in too much input or there could be a malfunctioning program or application.
Since you can't restart the computer on-screen, the best way to fix this is to do a hard reset by either holding down the power button until the computer totally shuts off, or by removing the battery.
After this, it may also be good to do a system restore to a time before your computer froze to make sure that there weren't any changes to your computer that caused the freeze.
Was dit antwoord nuttig?
Score 1
My pc doesnt work when i turn it on my mouse doesnt move on screen restart it and the pc is still frozen please whoever fixes this I need help.
Thank You
Score 1
1 Opmerking:
What if its a new one without a battery?
door
Remove the battery if you can, and if the device has a CMOS battery, remove that for 10 seconds. Replace both.
If you still get the same results, you may want to try replacing the hard drive, as I see this as a plausible reason for these symptoms.
2 opmerkingen:
How do I for sure get it unstuck
door
This is a new CP how can the hard drive be bad
door
Control + Alt + Delete and restart.
I’ve had this problem a couple of times, but this always fixes it.
Voeg je antwoord toe
Connor Watkins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 28,311
