Ga door naar hoofdinhoud
Reparatiehandleidingen en demontage-informatie voor Asus-laptops.
Correcting upside down display
My cat somehow changed my display upside down while I was sleeping. This has happened before, and I was able to adjust it back by Ctrl+Alt+Up Arrow, however; this is working this time. Keyboard is not locked. Any suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
Right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
If you have Intel Graphics installed , right click on the desktop, click on Graphics Properties. Select Advanced Mode click OK. Look for the Rotation settings, on the right side down near the bottom, select Rotate to Normal.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Appreciate the help!
door
@tore37 you did not tell us what OS you are using. Right click on your screen click on screen resolution. See what it says for orientation. It may be at something like landscape flipped etc. Sometimes reinstalling the driver for your video and then retrying the Ctrl+Alt+Up keys may work again.
1 Opmerking:
Thank you so much for your quick response! Will try when I get home from work ;)
door
Voeg je antwoord toe
Julie McNeill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 7,131
