Ga door naar hoofdinhoud
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
Upgrading to an SSD
I would like to replace the internal HDD which I have in my Mac Mini (Late 2014). The spec of my Mac Mini is 2.6GHz Intel Core i5, 5GB DDR3 RAM and 1TB 5400rpm HDD. I would like to upgrade the HDD to a SSD to improve start-up time, fast daily use and quick rendering in Final Cut Pro X. The SSD I would like is a 500GB SSD. I would like know if upgrading will it cancel my standard warranty and Apple Care? If not, is it possible to post my Mac Mini to you guy's to upgrade it as personally I'm not able to. Also how much will it cost for the upgrade if I provide my own SSD.
Is dit een goede vraag?
Score 1
1 Opmerking
Did you take out an extended Apple Care warranty?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Apple can get a bit fussy when people alter their systems either drives or memory (depending on the exact model and what you do). So you do need to use care here as you can damage things which Apple won't cover under warranty.
But before you decide on what to do, lets look at the options.
  • Swap out the HD for a SSD
  • Swap out the HD for a SSHD
  • Add in a SSD blade drive
Unlike the older series this system only offers one SATA port and a custom connector for an Apple proprietary SSD drive. As you got the HD model you are limited on swapping out the HD with either the SSD or a hybrid SSHD drive as the easiest options without needing parts but more involved in taking apart.
The HD model does not come with the needed cable to add in a second drive here (blade SSD) but it can be added! Making a dual drive config.
As you are using Final Cut Pro you'll need to think through how big a project you'll be working on. A SSHD or a dual drive config maybe the better way Vs going with a SSD swap out. Many people find they tend to need more space than 500 GB. Remember, you'll need to keep about 1/4 of the drive free so you don't over wear the drive. Smaller SSD's need more 1/3 of the drive free.
What would I do here??
I would look at going with either swapping out the drive for a SSHD if the Final Cut Pro projects are small in size and a dual drive if they are larger.
Of the different options adding in the blade SSD is by far the least amount of work but sadly a bit more expensive. If you want to take the least risky path this is what I would do.
Review here the needed steps to swap out the drive: Mac Mini Late 2014 Hard Drive Replacement. You only need the replacement drive here. But if you don't have already a backup drive you'll need this as well: Startech 2.5" SATA to USB adapter so you can prep the new drive as well as migrate your stuff over to the new drive.
Here is what you'll need to add-in the PCIe SSD: Mac Mini Late 2014 PCIe SSD Cable Replacement. You will need the cable and SSD drive for parts. Unlike the swap out you can prep the drive once you have it installed and switch the boot up to the SSD or you can create a Fusion Drive.
Mac mini Late 2014 PCIe SSD Cable Afbeelding
Handleiding
Mac mini Late 2014 PCIe SSD Cable Replacement
Moeilijkheid:
Gemiddeld
15 - 20 minutes
Mac mini Late 2014 Harde schijf Afbeelding
Handleiding
Mac mini eind 2014 Vervanging van de harde schijf
Moeilijkheid:
Gemiddeld
30 minutes - 2 hours
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Here's the frame with the blade SSD cable: Carrier, Hard Drive, with Flash Storage Flex Cable Apple P/N 076-00040
Here's one option for the SSD, OWC hasn't released their parts quite yet: OWC Upgrades for 2014 – Current Mac Mini. If you think this is the direction you're going give them a call. Otherwise you'll need to find an Apple unit.
door
Voeg je antwoord toe
Taef Dewan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 5,407
