Ga door naar hoofdinhoud
Een digitale camera die in 2012 door Sony werd ontworpen en geproduceerd. Een 18,2 megapixel camera met wifi, gps en een geheugenkaartsleuf.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Is dit een goede vraag?
Score 1
2 opmerkingen
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
door
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V behuizing vervangen
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 58
Altijd: 1,731
