Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Vragen Bekijk alle
Does this thing have a charging/status LED?
I'm trying to troubleshoot a G5 with no power. Battery is good, charging insert dock thingamadoodle is good, power button is good. But...I don't get an LED when charging or connected to PC and of course, no power when I press and hold the home button.
Is this thing supposed to have a status LED? That might help me narrow things down a bit.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
The image below, taken from the User Guide for a LG G5 from this website http://www.g5manual.com/ shows a LED indicator on the top section of the front of the screen. Unfortunately nowhere in the manual does it state its function!
Hopefully this information is still of some use to you
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yea...I found that too and I also couldn't find if it was on by default. I found how to turn it on but that isn't an option since the thing won't power on.
Thanks though.
door
Voeg je antwoord toe
Josh W zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 604
