Ga door naar hoofdinhoud
Deze pagina laat gebruikers zien hoe ze verschillende onderdelen van de Canon PowerShot SX260 HS kunnen vervangen. Dit omvat onder meer de vervanging van het LCD-scherm, het moederbord, de batterij en de ontspanknop.
Yanked off the Mode connector... now what?
So I was trying to reset the display connectors because I had the common problem of LCD screen going dark. But when I removed the back case panel, and had to remove the connector for the mode settings, which is attached to get the entire back cover off, instead of just sliding it up and out, I yanked off the entire housing. Is it ruined now? There seems to be no way to just pop it back into place.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
I do not know if you were using it but here is a link to the Ifixit repair guide(s) for your camera. Hopefully there will be some information contained in the various guides that will help you.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yes, I looked at those guides, but those are all "normal" repairs, like replacing lenses, screens, etc. My question is something I did out of the ordinary. Instead of pulling out a connector, I yanked off the entire housing for it. So if there is an expert out there on Canon cameras, my question is should I spend my time taking it into a repair shop, or is this toast now? (To be more specific, basically, I yanked out the entire white connector housing for the connector that attaches to the mode selector wheel. So now, I can't select a new mode at all - portrait, tv, live, p, av, m, etc. The connection to that is gone.) Is this a smoldering job, or is it not even worth trying?
door
Voeg je antwoord toe
Peter Oh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 245
