Ga door naar hoofdinhoud
Deze camera maakt deel uit van de HX-cameraserie van Sony. Het repareren van dit apparaat is vergelijkbaar met de andere camera's uit de HX-serie en vereist schroevendraaiers en wrikwerktuigen.
Wont remember language settings
Hi there,
When I set my camera to a certain language in the start up screen etc and turn the device off, then on again it does not remember the language I set and asks me to confirm the settings again. Every time.
This is very annoying, please can someone helps.
thanks,
Dan
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Have you also noticed that the date and time are missing from your pictures? If you have set the 'write date' option to OFF then possibly not.
If it is also missing and you have not set the 'write date' option to OFF and as you are losing your language setting as well it may be that the internal rechargeable battery has either gone flat or it is faulty.
This image is taken from the User Guide for your camera. (Click on the image to enlarge it for better viewing)
Afbeelding
Try the recommended method of recharging the battery and see it that resolves your problem. If it does not resolve the problem then unfortunately as the 'battery' is most probably a capacitor mounted on the motherboard and not a user replaceable 'battery' per se, the only way to fix it it to open the camera and replace the faulty component.
Here is a link to the Ifixit guide on how to remove the motherboard from your camera. I may be wrong but the round component on the right side of the motherboard may possibly be the capacitor in question. Sony Cyber-shot DSC-HX300 moederbord vervangen
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
actionmanxuk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 698
