Ga door naar hoofdinhoud
A corded, electric, 5 amp spiral saw power tool with a two speed motor by Rotozip. The device comes with a variety of drill bits, sanding and polishing wheels, and a carrying case.
Is it possible to replace the power cord?
I noticed the other day that the power cord on my saw is a little damaged. I don't want to risk using it like this, but the saw is still in good shape so i don't want to throw it away. Is there a way to replace the power cord on the saw?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hey Ezzeddeen,if you're having trouble with your saw check out the troubleshooting page. There is a way to replace the power cord; however, before you go ahead with replacing a part that you are not 100% sure is broken, you can test the cord for connection with a voltmeter. Here is a video that shows you how to test the cord. If you do want to go ahead and replace the cord, we also have a power cord replacement guide.
Was dit antwoord nuttig?
Score 3
@egazali , Yes power tools cord/plug can be changed normally fairly easily by power tool repair tech./electrician or if you want to give it a try google your type of saw power cord replacement. Check the link below to see if replacement cord available or if you will have to have technician make one up. Good luck.
http://www.ereplacementparts.com/
Score 1
Voeg je antwoord toe
Ezzeddeen Gazali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 626
